1985 Gti Cabby, 5 speed, 2.0 8v engine, sudden change in gear change, hard to select gears
(In Topic #194930)
was our for a drive today in my new (to me) cabby. Have driven it several times with no issue and the gear change had been very precise, not too loose or hard, no issues with selecting reverse by mistake… perfect in fact.
After a 20 minute spirited drive, got back near home an noticed it very difficult to find and select gears. Movement of the shifter is suddenly very stiff / reluctant and its v hard to determine which gear you are selecting. Gearbox appears to operate correctly in all gears once they are engaged, but it is almost impossible to drive it on the road safely.
So what have I done??? The sudden nature of the change (I think) precludes simple wear and tear being the cause, other than something somewhere must have fallen off, become disconnected or failed somehow? It might have been my imagination, but at rest, in neutral, i think the gear stick is sitting further left than it used to. Perhaps a bush has broken or I've lost a spring? Should I even be checking engine / gearbox mounts are in place (considering it has an engine swap)?
Any pointers gratefully received.
Gear Change Linkage - The Mk1 Golf Owners Club
Any ideas how to test effectiveness of engine mounts?
The problem has almost not recurred in the past few days so must be something transient (and minor I'm hoping)
