fuel tank cover/shield
Hi
Just wondering if someone can tell me if all mk1 1.8 GTI's(tintops) had the metal half/corner cover on the fuel tanks? (as per pic).
In a word....yes
Ok thanks,
Right next question (now i have acquired one) is can i fit it without dropping the rear beam?
Yes.  It is stuffed up on the corner to shield the Tank from Exhaust Pipe heat.
The Two tabs on the right of your picture usually have a rubber bit number 34a on them and Crimp down over the rear seam of the tank….
There is a rubber bung on the leading edge.
Bri does the rubber bit holding the heat shield to the tank act as a sump for the tank do you know saw it last night and wondered if it was attached from inside the tank thus creating a sump hole you can drain from? Ta
1991 Mk1 Golf GTi Rivage 1.8cc
113k on the clock
Owned for 16 years
No.
Cool mate thanks ill carry on with syphoning the old fuel out today from the port hole underneath the back seats
113k on the clock
Owned for 16 years
