Fuel pump problems ABF
(In Topic #202354)
Hi all had some work done on my golf and had to have the fuel pump and tank removed to weld in new sills but now its finished and all shiny in its new paint the fuel pump isn't priming when i turn the key??? any ideas where to look first? cheers
Which number fuel pump relay do you have fitted if a VW relay as some prime and some don't or is it an after market relay?
Mine never primes and I have no problems starting the car, you can bridge the 2 bigger connections where the relay fits to get the fuel pump running all the time to check the pump still works.
Hi the ABF's been in about 8 years now with no problems its only since the body shop removed the fuel pump and the tank just wondered if they connected it wrong or blown the fuse when reconnected it ?
If there is a standard fuel pump fitted it only has 2 wires going to it, a live and an earth.
Does it run with when you put a bit of wire between the 2 bigger connections where the relay fits?
Have you spoke to the body shop to see if they could fix the fault for you if you think they have caused it?
Cheersto be honest the cars up my unit so won't get up there till the weekend but will give it a go? yes its a standard fuel pump, am i right in thinking if its been wired wrong will it blow instead of suck? if you know what i mean
Shouldn't be able to wire it wrong as there are usually 2 different sizes ring connections used, unless it's been modded ?
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
I'll have to do some investigating the weekend do you know which number relay it will be? Cheers for your help👍🏻
Relay and fuse box layout,
No2 for fuel pump relay, I have No.62 in mine, there is a list of other relays which can fit and they have different rev limiter or may prime before starting.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Ffuze-box-wiring-layout_2&=
the above assumes its on a kjet relay, depending on what ecu it is and who wired it you may have a 67, 80 or 167 relay in slot 2 which is ecu triggered and not coil triggered
check all your fuses, 17 and 18 in particular again depending on how it was done and what ecu you may have an ecu relay triggered bu one of those 2 fuses
Cheers lads ill have a look
Hi all still no joy with the fuel pump checked all fuses all good, checked No 167 relay all good and checked the fuel pump by connecting straight to the battery and its working fine so I'm guessing there is a brake in the wiring ?? how hard is it to change ? I'm guessing its a big job?? cheers
ok now swap a 17, 18 or 100 relay to slot 2 and the fuel pump should come on with ignition. if not check the fuse again and the pump wiring from e/14 back towards the rear of the car. the fact it had welding may point to the issue, look very carefully around the areas it was welded may have burnt thru somewhere or pinched the wiring when tank was refitted
Cheers Jonny looks like its defy the wire somewhere is it going to be a barstool to change? will i need to drop the tank?
it depends where the damage is, if its outside the car a bit of a fiddle to pull the loom back into the car to repair it but I'm not sure what the access is like? probably worth pulling up the carpets to chase the rear wiring loom from the fusebox to the rear, hopefully it'll be something obvious.
1st check would be the earth, it should go to the white 4 way spade block behind the fusebox. may just have come loose during all the work…
Thanks again rubjonny ill have a look the weekend fingers crossed its not to bad
Just a quick one to let you know how i got on, turns out it was the battery at fault id charged it up but wasn't sending enough amps to power the pump!!! new battery fitted and all is fine now but cheers for all your help rubjonny you are a legend
