Cabby fuel line probs!
Hey there everyone, looking for some help!
In the process of rebuilding my 89' cabby 1.8 8v carb, I'm refitting the fuel lines etc at the mo! As its been a while since it was all stripped down, I'm unsure which way round the lines fit between the tank and the separator/fuel pump! I'm sure there the wrong way round! Has anyone got a diagram or picture etc to help me with this set up? Many thanks in advance, ash
any help? on the lifter pump the feed pipe is #7, return is #6. main pipe #1 is feed to engine, #2 is return
Ok yeah looks good rubJonny, I assume this is the gti set up as opposed to the 1.8 carb setup, does this relate in any way? Cheers ash
The line from the tank goes via a filter into the front of the pump(bottomright in the pic). It then feeds up to the vapour pot from the outlet to the feed (the hosetail that points towards the passenger side headlight. The hosetail at the top goes to the carb ( mine has another filter before the carb) and the other tail is the return line back to the tank.
1985 Cabriolet GL
Or at least that's how mine is.
1985 Cabriolet GL
duh sorry yes thats the gti setup ignore me :lol:
Ha ha no worries rubJonny, thanks for the info anyway! That's great julesgreycab, the inlet/outlet is marked on the top of the sender unit in the tank just to check? Cheers ash
No idea I'm afraid. Haven't got round to sorting out that far back on mine yet.
1985 Cabriolet GL
