2E2 first 7 seconds choke question
(In Topic #198214)
Hello All,
Needs some info about the first 7 seconds on a cold start with a 1.8 EX 2E2 carbureted engine
What I do now on start up:
- Turn the ignition key - don't start yet
- Push the gas pedal down for about 3 seconds
- Release the gas pedal
- Start the engine
- Starts up instantly
BUT:
If I don't keep up the revs the first 7 seconds it only idles around 500 RPM
7 seconds later it gets up to 900 RPM and everything is fine
Drives very nice through all gears - in traffic - on the highway - shifting down to a standstill etc.
My question:
Those seven seconds to my understanding is set by the heated electrical choke part in the choke housing and is just a matter of turning the complete choke housing when the engine is cold to set it up to a higher first seven seconds start up when cold 1200 RPM
Is my solution correct ?
If so what direction do I have to turn the housing to INCREASE the RPM ?
Clockwise or anti-clockwise ?
BerT3
- Start the engine
BUT:
My question:
BerT3
I checked the notches on the housing and the the one on the carb itself - these line-up
Clockwise or counter-clockwise to increase the cold start RPM's ?
BerT3
BerT3
I didn't realize there were notches on the choke and carb that had to line up! That would explain why my choke isn't opening properly. Where are the notches? Thanks for this
