1.8 2H engine exhaust systems
(In Topic #198792)
Thanks in advance
Website Manager
Vehicle exhaust emission standards - GOV.UK
Cars do not have to have a catalytic convertor fitted to pass the MOT test, however they must pass the CO and HC emission checks. From 1/8/95 lambda checks were introduced and must be measured and be within the defined limits. There is a huge Annex of engines in the above doc for engines between 1/8/92 and 1/8/95 where stricter emissions and control tests are required like the post 1/8/95 cars. A good example of this is the DX engine fitted to 1993 Cabby Sportlines is subject to 4.5% CO and 1200ppm where as your 2H engine is subject to harsher checks if it was registered after 1/8/92.
Lambda control was introduced to reduce emissions and also to stop the engine going over lean or over rich and damaging the CAT.
1/8/75 to 1/8/86 requires 4.5% CO and 1200ppm HC
1/8/85 to 1/8/92 requires 4.5% CO and 1200ppm HC
1/8/92 to 1/8/95 requires 4.5% CO and 1200ppm HC unless your engine is in the Annex at the back of the document above. The 2H engine is and requires 0.5% CO and 200ppm HC and a Lambda check.
A well controlled engine will easily pass even the 2H settings, for example my 230bhp 16V Supercharged engine in my MK1 just passed its MOT with 0.07% CO and 12ppm HC running an Emerald ECU and wideband lambda control !!
I hope that helps you decide :-)
Website Manager
Website Manager
