wipers gone nuts ?!
So my front wipers won't turn off! As soon as I turn the key they are on regardless of what position the stalk Is In. Any Ideas  guys? Thanks.
Rusty Hookers Dub Club
Take the two covers off your steering column first.
With the Ignition off look at the two brass connects when you operate the wiper lever.
Do they touch when on?
Do they separate when off?
Are they clean and bright on the contact side?
You get the idea! ;)
If it all is OK then I have no idea.  :thumbs:
Sent from my mobile phone.
pull the relay, its a 19 or 99 see if that stops em. check fusebox for water damage and corrosion
Cheers, tried pulling the relay and different stalks....but still the wipers go!
Am I right In thinking all the earths for clocks switches radio etc are on that spider next to the fuse box...and then everything earths through the body to the battery connection In the engine bay?
the fusebox and wiper motor earths to a white 4 way spade earth block on the end of the fat brown wire from the battery -ve, its behind the fusebox you cant miss it.
 there is also an earth from this block to the claw above the fusebox to earth that, then you got various bits and bobs earthed at the claw.
check your wiper motor & stalk wiring next, make sure there are no shorts. but im leaning towards a duff motor
I've gone and ordered one of those upgraded motors from mark carter (think thats his name ) If that doesnt sort It, It dies!!!!
