Wipers/gauges
(In Topic #193670)
Hello people, I'm in a little bother today i was using my wipers and it kept blowing the fuse I was using the washer spray to and after a few wipes it would blow the fuse in the fuse box the fuse is number 11 that keep blowing its a 8 amp fuse ( white fuse), with this blowing the centre clocks all stop working, is there anything I can check or so to see why this is happening, my wipers are really slow anyway, would this be normal, or would I need a new wiper motor, could it be a case that the wiper motor is struggling and blowing or is there any other way to see why it keeps blowing, there is a small clear box on the top row of the fuse box with a 8 amp fuse inside it, there looks like a space for another fuse, are these spare fuses or do they do anything, really need this sorted as I need to take it to a mot, thanks
The car is 1982 golf GTI,
Last edit: by BAZ-GTI
it should be a 15a fuse for the front wipers on the CE1 fusebox, I'm assuming yours is the older ceramic fusebox if the clocks also die? I'd assume you'll want a 15a for this one too as the wiper still uses same amount of power anyway.
i would look under the scuttle at the wiper motor and wiring for any obvious damage, corrosion or whatever, plus the wiper spindles could probably benefit from a strip, clean and regrease. The MK2/3 wiper motor is a good upgrade if non of the above helps, be sure to chop a good length of wire off the donor as the plug differs
The ceramic fuse is white with 8a on it, so it must be to low could someone give me a ceramic fuse box diagram so I know where the correct fuses and ampage goes, thanks, I have started to strip the motor and regrease it wire seem fine, thanks again John and my ceramic fuses are off eBay and of very bad quality anyone know a decent place to get these fuses will euros do them thanks
For the wiper/wash can I go for a 16a as I can't get hold of a 15a ceramic fuse, all help appriciated il send a pic of my fuse box it's not clear but just the layout of my fuses
Will try getting a better picture tommoro, but is this a ce1 fuse box ? Thanks
thats an old skool ceramic type, CE1 is later and uses proper blade fuses. Annoyingly the wirign diagrams I have dont mention the spec of the fuse so I'll have to dig out the haynes to see if it mentions it there
Thanks john, I'm going
To clean up the wiper motor so hope it help but il put a 16a fuse in and see if it helps, I was out this morning and saw the fuse box and there was droplets of water just above it from all the condensation and this weather was thinking is there any thing that I could use to cover the fuse box so it doesn't mess it up, I will be cleaning all relays and drying it out so it's clear of any water that may have got in to the fuse box, I also found a switch at the bottom of my dash on passenger side it near the fuse box it's not connected is this a factory fit on all GTIs and what's it used for, to me looks factory but not sure il post a picture up so you guys know what I mean thanks again
There no lose wires near it, i do have a twin headlamp grille unless someone tryed to use that as a fog light switch lol bit confused, lol put your fogs on let me onto the passenger side lol
on mine when my screen seal was leaking i put a plastic bag over the top of the fusebox till it was fixed lol
switch doesnt sound factory but piccy it up
edit: nope that aint factory!
The switch under the dash is for the hyperdrive, makes the car go at 10000000 mph… At a guess someone installed a home made immobiliser?
I would not install a bigger fuse if it keeps blowing as you may melt the wires or worse case the car catches fire! and that will be even more work to put right.
pretty sure that the fuse is blowing becasue its not the right spec, the mk1 with ce1 fusebox uses a 15amp for the wiper motor and i see no reason why the old ceramic fusebox would need a smaller fuse. after all its still the same wiper motor
Lol no need to do a engine swap with 1000000000 mph ,the guy at the motor factor said he didn't do 15a ceramic and to go closest which was 16a, but I'm hoping 16a will be ok I have re greased the wiper spindles, cleaned up the contacts, so I will re fit and try again, I will try again with a 8a fuse but, like John said I think it is a smaller fuse because I remember that had blow before, without using the wipers and it had killed the speedo to aswell as the vdo clocks, the car has been on the drive so I couldn't check speedo but the rev counter was jumping up when I turn the ignition this was with the blown fuse In the fuse box, will keep you guys posted, will dry the fuse box out and cover with a plastic bag lol
if you're worried about the fuse for ignition to dash being too high dont, on CE1 mk1 golf they had no fuse in the ignition live to dash at all
Lol so my 16a should be ok, and I do think the 8a is bit small if it uses that fuse for wipers/wash and vdo gauges and im sure speedo,
yeah i cant see it beign enough if vw decided a 15 is needed for the ce1 fusebox, as i say its the same wiper motor!
True, been bit busy this week but need to sort my wiper stalk out and put it all back together again, dry the fuse box and clean the relays and hope for the best lol
Hello I'm back right I'm still having problems with this number 11 fuse, I had replaced it with a 16a and i try to use my rear wiper first the water sounded and the wiper moved a tiny bit them bang and the 11 fuse blew this was with a 16a, is there any relay for the rear wiper I have just cleaned my relays ( sand papered connectors ) and sprayed load of bright spark electric contact cleaner on fuse box and on the relays I'm going to grease the rear wiper to see if this helps I also found a lose wire so just wondering where this may go thanks il post the pic of the wire I found
