Wipers and Blower Not Working
(In Topic #199981)
Many Thanks
PJ
Tarmac Adam said
Check ya fuses and check for power at ya wiper motor
Thanks, will do, results to follow!
PJ
Tarmac Adam said
If you have power at ya motor it will either be the motor or the linkage seized up so take the motor off pop the arms of the motor and make sure the shafts the wiper arms sit on are all free if so new motor required ,, as for ya heater blower do the same start at ya fuse and work back don't forget to check you have an earth as well lol is fuse is ok the check for power at ya motor if so make sure the motor turns nice and freely I don't know for sure but I would presume there's a heater resistor some where co check for power going in and out of that when you turn ya heaters on theses are always very common for going on a lot of new cars so there's plenty for you to go at and more you can do but there's a good staring point check ya basics and go from there good luck
Is there a constant 12v supply to the wiper motor?
Twitter Manager
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Fwipers-and-heater-not
Many Thanks
PJ
if not try another relay, the mk4 100 relay for SAI and x-relief pump is pin compatible with the 17/18 relay if you're going scrappy hunting.
if the relay isnt at fault look at the ignition switch, you shoudl see 12v at the black/yellow to pin X, check this and trace the wire for bodgery. this is what triggers the relay
rubjonny said
its the X relay '17 or 18 which powers both the wipers and blowers plus a few other things. make sure it clicks and wiggle it in the socket with the wipers and blowers switched on see if they spring into life.
Will do jonny, thanks.
PJ
