What kind of rotor arm is this?
(In Topic #186341)
1979 GTI 1.6 EG engine
I was about to change the plugs, distributor cap and rotor arm, with what I thought was the correct one like this;
but when I took the cap off I found this
What kind of rotor arm do I need? Is this a rev limiting one or something?
Last edit: by kp73
bottom one is a rev limiter type but has had its rev limiting mechanism removed.
not sure you can still get the limiting type anymore.
ah thanks, I thought it might be something like that. So I can just use the other type no problem?
can still get limiter type:
http://www.vwspares.co.uk/g1electrical.php
you can use non-limiter type no problem so long as its correct fitment for your dizzy, just no rev limiter obviously.
You are a helpful chap! Thanks. The car is running so much better already with new plugs and cap.
I'll swap over the arm too. I don't plan to go anywhere near 6900 rpm! Maybe order a rev limiting one for next time anyway.
Ahh, I wondered this myself when I was changing it over. Ended up ordering the rev limiting type off eBay £13 as I wasn't sure what it did. That makes sense though.
