What is this?
(In Topic #209550)
Just checking to see what this is?
Quick google search on Bitron Video 2043018 shows that it is a central Locking control or relay.
http://www.ebay.de/itm/2043018-549-197-12V-30A-6-pin-relay-central-locking-bitron-video/111619019947
Do you have electric Locks installed, as VW, used Vacuum operated locks.
What is this?
Haven't got car long and haven't started it up yet , door pins are gone, as is drivers door handle,it was fitted with some sort of alarm . I need to get knee board off and go thru wiring . As my fuel pump isn't coming on . I just put new relay in and it's not priming with ign. On
What is this?
There's two sorts of relay for fuel pump.
5 pin for the later cabbies.
Iirc.
Iirc.
What is this?
Thanks folks for info , will check out wiring to central locking as I think it's been partially removed. Also will check pins on fuel pump relay, new one looked different to the one that was in the car and old one was in two pieces and looked burnt out
