LED lights into the MK2?
(In Topic #215861)
Want to consult with you please
It has got round lights, and I am extremely unhappy with the light output, because of the scratched and dimmed lens.
First I thought of a sort of restoration, but then gave up this idea, because of too much hassle I am not really happy about.
Now, I saw those round lights, you know, sealed beams, with the LED bulbs for high and low beams, and with the lenses to focus the light.
I haven't found anyone on the US MK2 forums who has installed LEDs into this VW. That's why decided to give it a try and ask you folks.
What do you think? Will they work okay with a sort of aged wiring of my MK2?
Has anyone experimented with LED lights for high and low beams on the VWs?
Thanks,
Jeffrey
https://www.carid.com/images/lumen/sealed-beam/pdf/7inch-led-sealed-beam-headlights-installation.pdf
I believe that is the resistor that's requiered…
X5mark1gls said
Relaying your headlights is the way to go as VW set up the current runs all the way to the light switch then off to the headlights and you lose a lot of current going that far on old wiring.
here is how I did it back before kits were available, including the 2 relay and 3 relay diagram.
Relaying your Head Lights | Volkswagen Owners Club Forum
https://www.amazon.com/Headlight-Relay-Wiring-Harness-Ceramic/dp/B00H5JFHR0
or
https://www.ebay.com/itm/H4-Headlight-Ceramic-Relay-Wiring-Harness-Kit-Headlamp-Light-Bulb-Fix-Dim-Lights/201999671717?epid=1454606994&hash=item2f081e61a5:g:SxAAAOSwK21ZedYo&vxp=mtr
Last edit: by Briano1234
