Wrong Relay
(In Topic #203116)
I had to replace 2 relays today, by accident I mixed them up and turned the ignition on. Nothing happened. I then discovered that I had mixed them up and swapped the relays back to their correct slots. The 1 function (hazards 191) work and the other 1 (Windscreen and blower 19) does not work. Could I have blown that relay by inserting it in the incorrectly ?
Welcome to the club
justing69
Sorry I can't answer your question but there's a few that will, just takes a little time for members to catch up with the posts!
Thanks, my car was recently in a flood and the water came right up to the top of my wheels and inside the car.
unlikely, does the heater blower motor work?
if the water got up that high possibly the fusebox is damaged, check the fuses too some of them may have popped if they shorted out in the damp
Thanks for the advice. I got the hell in and sent it in and it turned out to be relay 53, the only 1 I had not changed. Fortunately it did not cost me an arm and a leg.
