Instrument cluster for 1983 gti
(In Topic #196747)
No instrument cluster for mk 1 1983 golf gti
I have a 1983 1.8l gti golf, my first, which I bought a few months ago and in the process of doing it up. However, I don't have a instrument cluster for it, so wondering do I need a specific instrument cluster for the gti, which are near impossible to get or can I get any other mk1 cluster to fit or modify to fit. Thanks for looking. Martin
if you dont care about either of the above any later single binnacle mk1 golf clocks will fit, though 1.0-1.3 speedo is calibrated differently.
if you want the mfa but not bothered about the mpg/shift light then later mk1 cabrio gti clocks will work, just you loose the mpg/shift light. only thing with these is you wont be able to switch between modes 1 and 2 unless you get the later stalk plus wire it to the 2 pin socket to the rear of the cluster
mk2 golf clocks can be made to fit with minor mods plus wire splicing even
