Thermo switch no supply
(In Topic #210241)
I've got a cold start issues . I've narrowed it down to no supply at the thermos switch. The supply comes from the ignition switch
terminal 50. When I did a continuity test from the ignition switch to the thermo switch, there was none. So does anyone know
where this cable runs, to the thermo switch?
Last edit: by soft84
the red/black on the thermoswitch runs to a spade plug behind the fusebox, and plugs into a spade on the headlight loom yellow connector plug C, pin 18. cant miss it
Thank you , you're a star
