swallowtail fuse box layout?
(In Topic #208623)
Does anyone have this to hand, is it the same as a base model S1?
I have a manual but its all in swedish, I had a blown 25amp fuse in the place I can badly translate as on of the side lights… Which is slightly worrying.
I want to know which one does what and what rating should be there…. Then I'll be able to iron out any issues.
Cheers!
Cheers!
The answer you are looking for is in the FAQ section at the bottom of the forum page.
The fuse layout link takes me to the home page?
Try this
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrical-faq_2%2Fs1-fuse-layout_2
Ah cheers mate, didn't see that!
Well everything is working bar the sidelights.
Fuse 14 blows when I switch the sidelights on? Need to dig more.
If I wire a random bulb across the sidelight wires the bulbs work fine. But the same wires connected to my sidelight bulbs in the headlight unit the fuse blows, just the left hand sidelight fuse?
Maybe the headlight connection has issues?
Last edit: by Roach
