Struggling to identify last connector on my dash loom
(In Topic #202316)
Theres a grey and blue wire (some kind of interior lighting linked to the dimmer)
Black and green that goes to a spade near the fusebox
Black which goes to the horn relay
Really have no idea what it's for, everything is account for
The loom was hanging out of the car when I got it, so never got the chance to label it
I've pretty much got everything labeled up on the loom now, apart from that and a few spade connectors on the fusebox end
Many thanks
I've looked at 3 other mk1's and they were all blade type, they didn't have this extra connector. Not that I could make out
Mine also doesn't have mfa for some strange reason, I thought all 1800's had mfa?
My managers is also an 82 and his is blade type
99% sure mfa didnt come in until the blade fusebox regardless of the engine type
rubjonny said
VDO oil temp gauge
Ah ok, that clears loads up, would explain why it has a illumination feed. But a bit confusing as it's not on the haynes wiring diagram. It would explain why it's an extra loom that unplugs
I ruled the centre console gauges out as I don't have any, they have blanks in. Also strange I have the loom for vdo oil temp but not any of the others
But thank you, was really scratching my head with this!!
Dash loom is done and repaired cut the immobiliser out. Didn't require as much repair as I thought
Also saves me a bit of hassle as I plan to wire the 3 gauges in anyway
Apologies before hand if I clog the electrical section up with "what's this" and "where does this go" for the next month th whilst I sort all my looms out! Saying that the dash one went smoothly, just got to triple check diagrams and everything
