Stray cut wires found behind 1991 VW Golf Mk 1 Cabrio dashboard ashtray
(In Topic #193169)
Last edit: by NoNameYet
Yellow, Yellow/White, Blue, Blue/White, a Brown one with a small female spade and a couple more in Blue. Also what I think was some kind of alarm LED (red)above the hazard light switch has it's wires cut off. Could it be they belonged to a factory installed alarm?
Red - permanent live
Yellow - switched Live
Blue - remote amp
Brown - earth (probably to one of the sockets/lights
Blue/white - Variable 12v from the illumination circuit
I'm not sure what yellow/white would be, possibly a sensor of some sort?
The brown wire is almost certainly an earth but the other wires could be something else depending on wether they've stuck to the correct colour codes.
Hope that helps
~Madferret
Mk1 1457cc 5door GX '83
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
