speedo / dash display
(In Topic #189825)
heeeeeeeeeelp
Will is be a case of having to replace the entire dash console/unit?
I have a k reg cabby (1992) - will i need a unit from an identical vehicle? The GTI version is very similar (and seeminly easier to find 2nd hand) but not sure if it will fit.
Also (and I know this is an idiots question) but what happens about the change in mileage?
many thanks - I want to keep this golf on the road…..
"I'm not even supposed to be here today"
the gti dash will just function as a digital clock if you fit it to your car without adding the mfa wiring
mostmk1 clocks use similar parts, but the earlier stlye may differ slightly. certainly if they look the same as yours but with mfa theres a good change the speedo will swap
shepp said
Dont need it for a MOT!
Yeah believe you are right, working speedo not a mot requirement, although handy thing to have.
From the MOT Manual,
6.7 Speedometer
Reason for Rejection:
2.
Speedometer incomplete, clearly
inoperative or the dial glass
broken or missing.
You can strip the dash apart and just change the needle but they tend to be very fragile (as you now know) and you will most likely break it when pulling it off the donor clock.
If you swap the speedo head you can adjust the mileage displayed back to the genuine reading if you want to but I wont say how on here! (it's not hard to work out).
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
