Speedo conversion km to mph
(In Topic #216378)
I've read somewhere that there's a 10 tooth cog I can get to Modify my Speedo, but I'm not sure where it goes and where to buy one. Any pointers would be appreciated.
I have an automatic cabriolet with no MFA.
Thanks.
Sent from my Moto G (5) Plus using Tapatalk
Thanks.
If you want the PSD Boot Sticker file, it's here: Boot Sticker
easier to just swap a mph speedometer in, technically you only need the face as the needle sits in the same place mph/kph, just the oddometer will be out if you do it that way
Re:
Thanks. That was one avenue I was thinking of. After I don't bought some mph stickers for my speedo, I realized the odo would be out.rubjonny said
Can't seem to find a mph Speedo from reasonable money at the moment.
We have the dubfreeze show here on this weekend, so I'll have a rummage there.
There were different gears based on the Manual Transmission that you have, red/green/white but they go in the tranny.
On the Autos that I own here in the US there is only one gear in the tranny for all varieties.
Only the Odo is Different, and depending on which type that you have as there were two styles over here pre-90 which was VDO and 90 and up was MotoMeter.
There are over templates on the cluster gauges that you can install, I think that www.cabby-info.com in the gauges and indicators there are some templates.
Depending on the year, the speedo cables change as to whether you have the o2 counter box or not.
