Reverse lights Not Working
Hi all,
The reverse lights have stopped working on my Mk1,a friend of mine said it might be the connector on top of the gearbox that could be faulty but I'm not too sure so any help greatly appreciated..
Important!
Hi Titan
Could you please 'Delete' all you duplicate posts on this subject.
Also if you could give the servers involved a chance to update the website in future it would help  :thumbs:
It should come as no surprise if I tell you we don't have the same computing power behind us like Google or NASA!  ;)  :thumbs:
Your Moderator Team.
Important!
Sorry about that,I thought I was doing it wrong cause the post wasn't going up,lesson learned!!
Hi Golf Cabrio,I tried to delete those other posts but haven't figured out how to do it..
How do you delete posts?
have a look on the box to see which switch you got, if its 2 pin simples just jump the 2 wires together and switch on the ignition see if the lights come on. if they do you know its the switch, if not then you know its a wiring, fuse or ligth problem.
if its the mfa multi pin switch its the black and black/blue wires you want.
you'll note that these 2 wires run to a 2 pin spade plug further up the loom, this is a good place for corrosion to build up as its not waterproof
