Rear window defroster wiring
(In Topic #208397)
Hey guys
The rear window no longer desteams. I have double checked with an electric tester that there is a current going to the back window but not too sure why it doesn't desteam?
do you see 12v between the spade connections when probed either side of the glass
rubjonny
hi mate, yea I tested it with 12v and there is voltage coming through (I have the switch on…). So annoying
In the Archive section I have a how to on repairing your demister lines.
If you have 12V on one tab do you have 12V between the 12v tab and the ground tab? That is the other side of the window?
If not then your tabs may have come unglued. They make conductive glue for the tabs it is usually sold in a Permatex Professional Defroster Kit.
They also include a small vial of conductive paint to repaint broken lines.
Hint, the rear demister has as you are inside looking at it
12v+ on the right tab, and Ground on the left tab.
I have had 12V+ on the one side to frame, but the wire for the ground tab had become broken and I had no ground.
