Oil temp, economy-light, I need a wizard!
(In Topic #212110)
I've got no oil temp and no economy light, the yellow one between the speed and rev gauge
Thanks!
Life Member
Re the econometer - have a look in the FAQs, there are quite a few comments in there.
Dan
the light is triggered by a vacuum switch in the engine bay on one of the thin pipes, it has red/white and brown wires to it.
does the mpg needle work in 5th?
rubjonny said
make sure the engine is hot enough, it will only display from about 50 degrees up. check the wire and sensor though, its the small white one in the filter housing with a green/black wire.
Yeah, it's hot enough alright. The display shows a few lines, that's it. But thanks for pointing out what colour the cable for the oil-temp is, the "head" of the sensor is gone so I will have to change that.
The lights vacuum-line has a check valve on it, should that be there or is that some "pro's" fix? I'll upload a pic when it's stops pouring down rain outside.
And no, the needle has never worked. I took the whole thing apart last week (I wasn't sure the hose was connected in the back, it was), and the needle is in there.
Thanks for the help people!
you need the multi pin reverse switch for the needle to work right, plus the control relay in the fusebox. if its a 2 pin reverse switch you'll either need to rig up your own switch, or live with either the upshift or needle not working
I did mess about changing the relay and it worked briefly, scared the living day lights out of me initially and then was just annoying. Flashing blinking lights on dash are bad.
Glad it stopped working again
