oil light flickering on idle
(In Topic #193579)
Oil light started to flicker on idle but goes out when moving . Abf engine if that helps. Oil pressure on vdo looks fine and oil level ok. Should I just replace the switch or could it be something else?
It's all shits and giggles until someone giggles and shits
As you have a none standard setup up, I'd look at the wiring first.
I'm no expert but I'd be looking closely at that before anything else!
Will do
How old is the oil and what are you using?
What reading are the gauges giving?
Properly about 2000 miles ago but only started doing it today.
Just had a look and the spade connector didn't look too cleaver and came off the wire in my hand so changed it and seems all good. Thanks chaps
All's well that ends well.
Still flickering once engine up to temperature. Please advise some more
Ordered a oil pressure switch, to see if will cure it as only happens when up to temp???
where is the 0.3 bar switch? are you using a 2 pole oil pressure sender, or is the 0.3bar switch seperate?
as above whats the oil pressure gauge say when light is flickering?
I have no idea what you even said there
gauge readings look fine while at about 15 to 20 ish, it's only when iv been driving for more that about 30 mins.the switch is blue with one spade connecter if that helps?
Last edit: by sallyandsean
basically, on a stock car you have 2 oil pressure switches a blue or brown 0.24-0.3 and a white 1.8 bar. the 0.3 bar one is responsible for triggering the light if pressure drops below 0.3 bar at idle, so for your issue you can ignore the 1.8 bar switch and concentrate on the 0.24-0.3 bar switch.
now for the oil pressure sender, some have 2 poles on them 1 for the gauge, 1 for the oil pressure switch warning. the 2 pole ones replace one of the old pressure switchers, and the most common ones replace the 0.3 bar switch. this is i ask if you have a 0.3 bar switch, or if you have a dual pole switch for the gauge.
also, oil pressure is higher at the oil filter housing than it is at the cylinder head which is why i ask where the 0.3 bar one is
what does the oil pressure gauge say when the light is actually flickering?
thats way too high, cold it should be around 5 bar then drop as the temp rises to roughly 1 bar.
maybe the pressure relief valve in the oil pump is stuffed
Better look into that then cheers pal
Think I'm ranking talking in psi not bar!!
ah
10psi is 0.7ish bar so it shouldn't trigger the light. maybe swap the 2 wires on the oil switches over? they're opposite colours from abf to mk1 so it could just be that
rubjonny said
ah
Ha ha. Will give that a go pal.
