Name that plug!
(In Topic #197661)
rubjonny said
looks liek it goes to the aux air valve, wee box attached to the turret on driver side with some vac pipework to it. if you dont have one then dont worry about it, this was only on later kjet cars. if it is for this valve then you will have a relay above the fusebox that makes it work
Fuse box is a bit of a mess and I try to avoid looking at it at the moment! I have the aux air valve behind the inlet manifold which has a connection…
Next up and my main concern is this:
Under the coolant tank, yellow/white and brown. Looks important!
Then this one:
Green plug with black/yellow and white? Exits roughly around the brake master cylinder area.
The last unaccounted for plug was this one, white and black, which looks like it fits here:
Finally, the distributor has a spade connector on one side, but I dont seem to have a spare plug/connector for it….???????????????!!!!!!!!!!!!!
front fogs
throttle switch
cold throttle enrichment valve, you have it in the right place the valve also needs a vacuum pipe to the end to work properly plumbed into the inlet somewhere off one of the brake servo hose nipples. its there to give a spray of fuel via 5th injector if you boot it on a cold engine
dizzy spade is probably for the earth shroud, its there to help reduce radio interference. many dont have it and it doesn't seem to really make any difference anyway
I'm guessing that it doesn't need the additional air thingy then? and that these 2 connections are probably connected to said air thingy and can just be blocked off?
Throttle switch - it doesn't have one. Which I think is ok..?! It's a DX k-jet btw.
And I had a spare small bore vacuum line coming off the brake servo side of the inlet manifold which I wondered what to do with, so I guess I've found a home for it now!
you can see in this picture the air pipe which fits to the back of the head between cyinders 3 and 4, it's for the fuel injectors to add air to them, air shroud injectors.
the nipple on the head is for the later air shrouded injectors, if you got nothing to go into it you can just cap it off as it doesnt really do a great deal.
