Mk1 pre 83 Inner Grill Lamps
(In Topic #193079)
Fog or Spot Lamp
What are the inner lights on a pre 83 Golf Mk1 hatchback / cab? fog lights or spot lights ?. (this topic may also apply to later Mk1 cab)
I have purchased with varying success and failure, inner grill lamps to make my current project GarytheGolf look like my original 77 Golf shown in my Avatar.
Back in '78, I purchased a brand new Hella grille upgrade which included Hella spot lamps which came on with my main beam, I also fitted rectangular fog lamps below the bumper which were operated by separate dual fog lamp switch which also controlled the rear fog lamp.
For my current project I purchased a Hella grille with two TF15 / 24560 "spot" lamps fitted, unfortunately lamp one was corroded. So I have been trying to replace the defective one.
I have been receiving a mixture of lamps (good and bad) with the following markings from top to bottom on the glass: both fit in either left or right position (unlike post 83 Mk1 Golfs / Cabs), my last delivery was one of each, described as left and right lamps.
TF15 / SAE 080 / HR / E1 / 37,5 / 24560 R8 / 301-124 038
and
TF23 / SAE Y 87 / HR / E1 / 17,5 / 34525 R8 / 301-131 040
It is noticeable that the TF23 / 34525 lamp has a heavier set of vertical ribs in the glass than the TF15 / 24560 lamp .
I suspect that the TF15 / 24560 lamp with the lighter ribs is a spot lamp on the left and the TF23 / 34525 lamp with the heavier ribs is a fog lamp on the right.
Can anybody verify this? or have any other information on the topic.
Thanks in advance.
http://translate.google.co.uk/translate?hl=en&sl=pl&u=http://forum.vwgolf.pl/viewtopic.php%3Ft%3D211454%26start%3D30&prev=/search%3Fq%3D301-124-037%26biw%3D1024%26bih%3D671
fogs came as standard on Campaign, Driver and possibly the GX model ( Massbad69 should be able to confirm this as he has a mint original one) when the Cabriolets came with four lamps as standard, they were I think a different design grille and were spot lamps.
Last edit: by RichardHall
paul_c said
AFAIK spot lamps as aftermarket or option; and fog lamps on the genuine Campaign GTI. Not sure what the lights on 4 lamp convertibles once they started having them fitted as standard.
RichardHall said
Not sure if this will help, it was a Google translation of a german site talking about the inner lamps, I know the Campaign fog lamps end in 037 and should have a B 0n the lense which I think this article relates to being a fog lamp.
Guys, thanks for the info. I am sure that this discussion will continue.
I have never knowingly come across AFAIK before, is this another manufacturer of lamps?
I do know there were other aftermarket grille kits for sale in the 80s, like VHS in the VCR market, Hella seemed to be the most popular one to come through for the Mk1.
I suspect VW offered or included spot lamps as standard on some models as the headlights were so weak.
The translated link is an interesting read. None of my lamps have "037" or the letter "B", So I am now starting to think that both TF15 / 24560 and TF23 / 34525 that I have are spot lights, maybe a different batch or design of manufacture?
I do have a Golf GX brochure, quite clearly the GX was fitted with Fog Lamps. Maybe Massbad69 could provide some info / the markings on the lamps he has installed.
as far as I know
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
One post suggests 037 & B is a fog.
Another post suggests that a lighter rib is a spot, a heavier rib is a fog, however, only if fitted with the correct bulb fitting, i.e. without a metal cap for spot and with a metal cap for fog.
Cat among the pigeons?
Assignment twin headlights
Posted by: Turtle (IP known)
Date: 08/03/13 18:01
Hi there,
I shot an original double headlight grill for my Golf GTI and am still a little doubt on whether these are remote headlights or fog lights.
Contrary to my headlights installed this grill has installed the following Hella lamps:
301-131-040
34525 R3
Unfortunately, it is no label or TF TN on the headlights.
Can anyone tell which lamps are to me?
greeting
Michael … of the last few days has driven the Gulf again really hot … yawning smiley)
Options: Reply To This Message - Quote this post
Re: Assignment twin headlights
Posted by: Sebastian Heiss (IP known)
Date: 08/03/13 20:18
Hi Michael,
Deputy doch mal rein photos. Based on the strength of the corrugation in the glass and the fact whether before the bulb is still a metal cap or not, you can assign it.
Cap before pear and stronger ribbing in the glass = fog lights
No Cap and weaker ribbing in the glass = Spotlight
Greeting Sebastian
__________________________________________________________
_____
Jetta Diesel C 09/83 alpine white (daily driver since 1985 - but not in the winter)
Golf GTI Trophy 09/83 helios blue metallic
Posted by: Rycan Rudolph (IP known)
Date: 03/09/13 06:29
hallochen,
standing on my Neb'lern
301-124037
8364R19
As Sebastian wrote, diffusing glass and lamp cover,
many greetings Rycan
Posted by: n b (known IP)
Date: 10/03/13 18:20
Quick question … Have the opportunity to buy headlights from a golf1 cabrio … I'm not sure whether it is the right …
Are these the fog lights woauch on pirelli / trophy installed true?
At the top is geschriben.
TOP TN 15 SAE F80
is below geschriben.
B E1 (circled) 8364 R19 and the bottom left: 301-124037
MFG
Date: 10/03/13 19:02
Hello,
that could be suitable. One must be careful just because were installed in a convertible from 1988 twin headlights cricket that had completely different light fittings (incompatible with those of the dimensions of the limo).
Greeting Sebastian
_____
Date: 10/03/13 19:13
hallochen,
the figures are indeed as I described, and come from a convertible from 83,
many greetings Ry
Date: 10/03/13 20:04
Rycan Rudolph wrote:
> Hallochen,
> Figures so as I described,
> And come from a convertible from 83,
> Greetings Ry
Accordingly, the pasen in a gti grill and hella DSW are the right ones.
Posted by: Andrew (IP known)
Date: 11/03/13 06:12
Sebastian
But on the lights of the new grill variant should not be TN.
They had to my knowledge ever spotlight.
Golf 1 GTI Pirelli June 1983
Golf GLI 1 March 1984
Golf GL TD 1 March 1983
Golf Genesis 1 June 1993
Date: 11/03/13 17:04
Hi Andrew,
irgenwann was a choice between auxiliary lights or fog lights?
Or what was standard, though additional?
Thank you for `dig into the old sales data.
Many greetings Rycan
Date: 11/03/13 18:19
Pirelli had fog lights as standard.
The issue with the convertibles and fog or driving lamp we had ever. I mean but without the correct result.
Convertible from 1988 always had in one piece grill headlight.
Regards, Andreas
Date: 11/03/13 18:21
Hello Rycan,
something I have in my head. winking smiley
From work there was in limousines special models LX, GX, Pirelli GTI etc. only fog lights. When Cabrio it was to my knowledge until 1988 as well, then there were spotlights. An election there were not at least for the sedan.
Anders course for purchased as accessories.
Greeting Sebastian
_____
Date: 11/03/13 18:57
Thank you two,
Sebastian, who has so much in the mind, the night can still enjoy the comfort? ;-)
Many greetings Ry
Date: 11/03/13 19:07
Sebastian, now a question for headaches: Is this normal when I use the turn signal lever for Fernlichtanschalten, go to the fogger? For me this is so. Wide light is connected with fog light! ? Funny?
Greeting Ry
Date: 11/03/13 19:19
Someone has umgebastelt front what. The fogger must be turned on by the switch next to the radio and the high beam should be in the headlights.
Date: 11/03/13 19:54
Thanks for the info. Well I probably again a (small) site.
Greeting Rycan
Date: 11/03/13 20:22
Hi there,
I have finally found the login data of my account for the images. smiling smiley
I hope now funzt also.
Here is a picture of Lights:
http://img35.imageshack.us/img35/8113/doppelscheinwerfer.jpg
Can you assign this?
The grill is in mint condition which the headlights also very passable.
Therefore, I would like to convert, if it is remote spotlight ….
greeting
Michael
Date: 11/03/13 20:57
Hi Michael,
it may be a spotlight to 99%.
Greeting Sebastian
_____
Date: 11/03/13 21:01
Hi Sebastian,
Class, thank you. Then I got next weekend again something to screw …
And, there is Veterama ….
Is there anyone at the Hockenheimring? I ask again separately winking smiley …
greeting
Michael
Food for thought
Thanks in advance and clearly I'd need 2.
Regards
Hope this helps.
http://www.ebay.co.uk/itm/Front-fog-lights-wiring-loom-VW-Golf-MK2-Jetta-MK2-1988-1992-/111530170831?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf&hash=item19f7b759cf
http://www.ebay.co.uk/itm/Fog-Light-Cable-Vw-Golf-Ii-2-Wiring-Loom-Harness-Cable-Set-Plug-Fog-/371212216565?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item566df8e8f5
I'll give one of those a try.
Regards
Paul, my apologies for not understanding AFAIK in your response.
The expression was used at work yesterday, surprising nobody in the office knew either! Just shows what a lot of dinosaurs we have here!
I believe you are correct in that most spotlights are an aftermarket option
A final solution, just seen this on ebay advertised as a Fog Lamp, heavily ribbed, it does have a letter "B" on it as suggested by Richard.
http://www.ebay.co.uk/itm/Vw-volkswagen-golf-mk1-mk2-inner-fog-lamp-left-hella-/111569779745?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19fa13bc21
I can only assume all others without a "B" but have "HR" are spot lamps.
