mk1 golf brake wiring
(In Topic #211334)
I checked the fuses they are all fine and number 2 is getting power 12v.
I ran a live to the live to check the wiring and the lights work with direct feed.
What's the best way of sorting this ?
Thanks in advance.
Then I would suspect a Fuse, or a broken wire to the Brake Light Switch.
If the Fuse has 12V both sides then there is a wire break between the back of the Fuse box to the Switch.
You could run a 12V switched line (with a in-line fuse holder) to the brake switch, and just be done with it.
I personally prefer to have my brake lights on a un-switched 12V+ as that way if I am Pushing the car, or whatever I have rear brake lights to let the folks know that I am braking.
Kindof like I prefer to have the horns on a "Unswitched" circuit so I can Honk whenever I feel like it.
