mfa problem
(In Topic #183374)
mfa playing up
If still the same read out then there is a problem with the MFA which is more than a reset.
rubjonny said
you can just pull the fuse instead, #3 on the later blade fusebox
Cheers will try when I get home
I pulled #3 fuse and it reset the mfa clock digits came back may be a daft question but do the mpg oil temp and everything else only come on when driving as I press the stalk and nothing happens when stood doesn't change anything
rubjonny said
oil temp only works above 50degrees, mpg iirc will show low figures when sat but obv it wont show anything useful unless you're driving along. it should cycle thru all the modes though for sure
Yeah doesn't cycle when I press the stalk on the end just stays on the clock no arrows come up or anything any ideas mate and does the engine need to be running to cycle through the modes cheers
rubjonny said
nope just ignition on. check the mfa stalk wiring next, is it a later one with 1/2 button and push on the end? if so its a 4 pin plug. 2 of them run to a 2 pin plug that plugs straight into the back of the clocks, one of them goes to the main plug on the bottom and the last one goes off to the fusebox area to a male spade plug along with the clocks earth. then a wire from the engine bay plugs into it. check the wires to the side of the head to start with, one of these is the dash earth its a brown/white ring terminal.
Cheers will check yes it's the later one with the 1/2 and push button I notice when I was taking the number 3 fuse out there was a spade connecter near the fuse box that was gust hanging down not plugged in to anything could this have something to do with it and we're is the wire located at the side of the head please cheers
as for the spade it could be anything, whats the wire colour? best to trace it as it might be a random extra put there by someone
rubjonny said
it should be on the side flange nut, but it coudl be anywhere these days. basically just look at your wiring to the engine for a brown/white wire and check its clean and tight. while you're there may as well check all the other wiring you can find
I think the wire was red I will have a look around engine bay at wires see if I can see anything that may look suspect I appreciate the help mate
hi mate checked wires in engine bay earth strap was a bit loose but cant see any broken wires and all spades seem secure going to check that red wire neer fuse box tomorrow what would you say next stage would be cheers
if you get a loop of wire and pop it into the earth pin, then poke it into the others one at a time the mfa should react, try them all one of them will do the mode select button. if non of them do this then its the wiring or clocks. if it does react then look at your stalks
of course it may be you have some non-mfa internals swapped into an mfa shell!
