MFA Dead
(In Topic #207025)
The MFA on my nice campaign has given up completely, for years it's only showed me the time but now it's completely blank, I've checked the fuse(s) and they're fine, is there a place that repairs them these days?
2 1983 Campains (concours & track)
1985 Blue GTi Ragtop
2001 Bora Estate TDi SE (very very rare)
2000 Golf TDI commuter
2005 T5 Transporter with 394000 miles on it!
check the pins on the clock plug for starters, make sure they're all straight and tight. the wires to look at in particular is the brown and the red for the MFA screen. Check across these pins for 12v, and between the black and brown for ignition live.
I assume the rest of the clock features are working? if anything else is playing out look for the clock earth to the side of the head its a brown/white wire with a ring terminal on the end
Hi If you haven't had your clocks repaired yet try Cluster Repairs, email: admin@clusterrepairsuk.co.uk
Tel: 01992807908
Hope this helps
JD1
Tel: 01992807908
Hope this helps
JD1
