Main beam tell tale light
(In Topic #186539)
anyone give any tips? Electrics are not my strongpoint.
car is golf mk1 cabriolet 1.8 gti 1990
cant believe this is the only thing between me an getting the mot.
Premium Yam Yam
The car is my daily and is now off the road with no mot due to this issue. Really need to try and fix.
Premium Yam Yam
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrical-faq_2%2Fhelp-main-beam_2&=
so hopefully this is now resolved. Will check it in the morning if still ok back to the mot centre to get it signed off!
cheers for everyone's help.
checked the the blue light this morning, not working again. Cancelled my retest again.
Called in a favour from an auto electrician, he took the dash apart found a burnt wire! Going from the sidelights to the ignition, replaced that we weren't sure what it was for and were pushed for time so cracked on. Fixed some other dodgy looking connections and once again blue light starts working, success! No aparantly not, after putting it altogether again the stupid blue light stops working again!!! Ahhhhhhhhh….
dash apart again, another connection soldered. Blue light working again. Whilst reassembling constantly checking it's working all good. Soon as we're done the stupid thing stops working again!
so once again dash apart again! This time he wired in an old led on the dash (old alarm system or something) and put everything back together again. So know the blue light works and so does the back up led. I've went from no lights to two!
So we labelled the led which is next to the hazard light switch 'main beam'. This should get it through its mot, but further investigation is required.
On the plus side the indicators now work when you set and unset the immobiliser. Pleased with that, something else fixed without even trying!
dont these old cars take you on a journey into the unknown.
I forgot to mention last night my electric roof suddenly started working again after messing about in the fuse box. So know everything electrical in the car works. Good times
car booked in for tomorrow at 8.30am for retest.
also worth lookign at pins to make sure they arnt squashed, bit of a bend with a pick sort this. you can open the flap on the back of the plug to take the pins out, just watch out for the red wire this is permanent live so take the fuse out first or be very careful
