Loose plugs in engine bay
Its a male and a female plug. Do you know what it could be?
location? Back up light switch connections
On the top of the gearbox
What do you mean by backup light ?
Reversing lights….
What colour are the wires and where do the wires go, it's really hard to see in the picture….
Well Make Model and year helps in decoding the wire colors, but the Browns are ground.
Are the others white/red and white/black or white/blue or green? as those would typically to me to be the upshift indicators wires from the dizzy and the transmission on the later Scirocco's.
1985, 1.8 dx engine
Yes, one is white/red and the other white/green!
those are for the MFA shift light & mpg needle. green/white is for the  early type multi-pin reverse switch, it tells the clocks you're in 5th gear. the red/white is the vacuum switch for the shift light, and brown is the earth for both of the above
So… is it something missing?
Where should I connect it?
yes there would be a section of loom from those 2 plugs to the early style multi-pin reverse switch and the vacuum switch.
however I can see you have late style 2 pin reverse switch, so even if you had the loom section it wouldnt plug in anyway.
you only need this loom if you have early type clocks with the big MPG needle up top with shift light, if it has later clocks then you dont need to worry
