Instrument panel connector
(In Topic #207020)
Instrument cluster terminal connector numbers
1 - blu/gry - Light switch pin 58b (dash lighting)
2 - brn - Earth
3 - pur/blk - Fusebox pin B/3 (fuel level sender)
4 - blu/yel - Fusebox pin B/7 (coolant temp sensor)
5 - red/blk - Fusebox pin B/19 (rev counter)
6 - red - Fusebox pin B/12 (permanent live)
7 - blu/wht - Fusebox pin A/28 (high beam warning)
8 - red/wht - MFA switch mode button
9 - blu/blk - Fusebox pin A/4 (high oil pressure warning switch)
10- brn/red - Fusebox pin B/6? (glow plug?)
11- yel - Spade to engine loom behind fusebox on early, Fusebox pin B/15 late (low oil pressure warning warning switch)
12- blu - Fusebox pin A/16 (alternator warning light)
13- blu/red - Fusebox pin A/17 (indicator warning lamp)
14- blk - Ignition switch pin 15 (ignition live feed)
You may want to add a separate ground from the wire side of the connector pin 2 (brown) to a earthing point.
You might want to place a single piece of electrical tape on the plastic tongue of the unit under the pad side of the mylar, it tightens up that connector preventing intermittent issues
