indicator problem
Hi all, wondering if anyone can help me. My indicator light is glowing on my dash, indicator and hazards work fine but when indicators and hazards are off the indicator light still staying on glowing. Anyone had this issue? Thanks
sounds like faulty hazard switch
New hazard switch. There ignition live there . Don't know what it is
genuine or pattern part?
Pattern. When I unplug switch light still dull lol
hmm, try unplugging the indicator stalk plug next, has black/white black/green and black/white/green wires.  If that doesnt help pull the flasher relay, check for damp/corrosion in the socket/relay pins
Done all that mate . even put new relay in. Indicator and hazards work fine just dull light! Thinking maybe faulty switch or clocks
well if still dull with relay and both switches out its a wiring fault or problem with the clocks. check the earth for cluster to start with, if car has the MFA dash it goes to the side of the head, if not it runs to earth claw above the fusebox
Clocks have mfa but not using it so left plug disconnected.
right then, if the mfa was factory fit check the side of the head for dodgy looking earth wires. if not then check above the fusebox for dodgy looking earths
If everything works ok, is there a problem? My indicator sort of glows dull green, but that's normally the least of my worries. You'll soon forget about it when something more major packs up!
Campaign Mk 1 Black
16v Mk2 Red (decsd )
its an indication of a problem to come ;)
my mk2 did the same when it came out retirement, then after a week it stopped. great i thinks, bit of damp or whatever. then a few days later indicator stalk packed in completely ;)
