indicator issue Help Plzz :)!
(In Topic #191006)
When i indicate left i get both left and right lights on and i even think fog lights flashing to… same case when i indicate right.
the hazards are working fine no issues.
Its like all bulbs are flashing once i indicate left or right … im confused ive changed relay for hazard light.. checked the ground …
Any help would be amazing
Thankss
harshalkumar240 said
Hi guys wondered if someone could shed some light on this as car is due its MOT.
Thankss
Hi guys any help would be appreciated ive googled this and guess it might be the hazard switch? Before i buy a new one is there anything else i can try???
Thankss
just been out and done a few things reinsert relay and now when indicate i get both indicating lights on left and right same time flashing… hazard light works fine.
Thats my new problem lol any ideas?
rubjonny said
Hi
Thanks for that.. I have followed those steps and now changed the hazard relays and hazard switch cleaned earth point under fusebox.
Any other ideas? Checked all bulbs etc.
Bandit24 said
Hi my indicators have just stopped working both left and right. I have just fitted new hazard switch and hazards are working fine! The dash green light comes on but none of the flashers light up so any ideas chaps?
Hi mate
my issue with the indicators was solved.. when i got the alarm fitted the guy did not connect it properly it was back feeding causing the indicators to flash every time i indicated, im not sure of the technical terms but thats how it was solved lol.
