Help with starter motor wiring
(In Topic #166599)
MK1 GL cabby GL 1600 1984
Have I got the wiring right. Not sure if the two wires with the yellow sleeves go on, the top and bottom threaded bolts. Or maybe they both go on the same threaded bolt? Also I can not see any wiring that goes on the 2 spade connectors. I can not remember if there were some on them before I took the starter motor off. I can not seem to see any in the engine bay either! Should they be some ?Thanks
