fuses and relays advise please
what fuses and relays are missing? i have no power and its for an abf. thanks
It's normal to have a couple of relays missing, there is a guide on here somewhere to the fuses and relays or there is a guide on rubjonny's signature.
Sorry can't be much more help as not worked on a car fitted with a ABF engine.
I think It should be an abf relay (165 906 381) and 15 amp fuses as the other 2 are. I'll try that and see how it goes. Thanks
yes the missing one does appear to be setup for a mk3 gti/16v ecu relay #30, fuses its hard to say without knowign how the loom was made. looks liek one of William Skeltons with the fuse carrier.
any VW part numbers on the double relay carrier? thats quite handy if it fits on top of the fusebox :)
Hi, its 357937501 for the double relay carrier. I've still no power. 20160317_150749 (2).jpg where do these plug into? the red one is coming off one of the 15amp fuses
yellow wire spade is oil pressure switch, should be a mating plug on the dash loom.
other spade is it green/red? thats for the windscreen washer pump if so
pulled wire I cant say for sure as it depends on what the loom maker did, have a close look around the loom for evidence of where its been yanked from. Id start with the double relay socket but it could have come from anywhere really
ideally need to find out who made it and ask them!
Thanks, It was from barry venn so might take a week for him to reply. It was snipped and left along with 2 brown wires. Think I'll have to do some investigating.
diagnostic port perhaps?
