fusebox relay HELP :(
(In Topic #193244)
Hi
I want to know what relay go into the slots ive added a picture of my fusebox.
n is hazard and turn signels
m is wipers
k is a kind of "charge up" for the system
m is wipers
m is wipers
Hi
Thanks for the Reply, which one is fuel pump relay?
L is the fuel relay, you need one with a fuse pushed into the top of it.
some had a factory recal where the fuel relay was fitted above the fusebox, as the fuel pump pin was prone to burnign out thanks to the pin beign under-sepc to take the load.
the empty socket above the fusebox is probably the rear wiper, but check wire colours
Hi mate
Thanks for your reply, theres a block on fuseboard at the top if you look at the picture its got a fuse inside it i believe thats the fuel pump relay i think lol.
the fuseblock on the right there is for the rear fogs, if it had front fogs the other one would be used too
for the old cermaic type fusebox the fuel pump fuse is fitted in the end of the relay:
