Fuse Box
Hi guys has anyone got a wiring diagram for this fuse box? its in my Clipper cabriolet 89 1.8 auto
You really need to view www.cabby-info.com
You really need to get a Bentley/Haynes, and you really need to know about a2resource.com.
thanks briano i have identified my fuse box great site
Hi pal i have a couple of questions been searching the forum for the past few hours, where are the resisters of the heater located? have you a link to the blower replacement guide thanks pal
A/C or non-ac and year specific.
Older models had a resistor pack on the side of the airbox that once removed looked like a bunch of wire springs and not a resistor per-say.
Later models had either a replacement resistor attached to the Motor, or on the Cabbies with air a resistor that was welded to the motor.
Excellent all done with the help from you guys.
I can confirm the motor is well and truly seized ' know to find a replacment, would you think the resister pack would be ok ? IMG_0639.JPG IMG_0636.JPG
HEATER BLOWER MOTOR
well it says it will fit what you think guys?
