Fuse box & wiring layout (flow) for Y reg 1.8 GTI
Need help please!
Hi need fuse box layout & flow diagrams for my y reg 1.8 GTI tintop,
having serious connection problems, no heater fan, no wipers, water jet, the list goes on!! plenty relay buzz though.
Any diagrams would be great as I have tried another KLO 171 941 813 D fusebox.
Cheers Lads in advance
the brown haynes manual covers this model, the diagrams you need are in the suppliment section not in the main wiring diagram section
Just a point, but check and make sure your earths are good! I had serious problems with my vehicle and turned out to be a simple solution.
I have checked earths & even added more to make sure, relay 17 still buzzing, just need wipers & heater fans working, I am desperate to get this little tinker mot'd :-(
make sure the chunky earth from the battery that comes in with the lighting loom is connected, there is a white double spade connector which then plugs into a white 4 way spade connector. there should be a wire from here to the claw above the fusebox, plus another wire from here to the thick brown wire on the white engine loom plug
try another 17/18 relay, could be the 17 relay is bust
