fuel pump relay wiring
(In Topic #199268)
1981 1.6 GLI
Can you show us some pictures of what you mean?
you should have a plug which pops to the original relay socket to trigger the pump, and 1 wire for the pump relay power output from relay pin 87 that goes to the fuel pump power distribution spade block near the A pillar, its a 3 way spade connector inside a lump of clear plastic
the 2nd wire might be a permanent live, if its runnign from the relay pun 30 pop it to one of the H spades. See the s1 fuse box section near the bottom here:
http://www.clubgti.com/showthread.php?219775
