Fuel pump relay & fuse box
(In Topic #199594)
Campaign on EW chassis no. with relay 321906059F. Car wouldn't run; fired and died immediately. Replaced fuel pump relay and it ran OK briefly then wouldn't fire at all. Then it ran with the original relay once but that was it.
Replaced fuse box which had green crusty bits in it; no difference.
Got another new relay and it will now run on tickover but any attempt to raise revs brings rapid rising and falling of engine speed accompanied by loud ticking from the fuse box.
It's as if something's telling it "you'll get fuel at 800 rpm but no quicker".
Neither of the old relays now works at all but the car did run OK if you took the relay out and bridged the slots in the fuse box.
Any advice much appreciated.
Cheers.
Hope this helps
LeeO
2001 Zafira 1.8
2001 Zafira 1.8
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
The rev counter works ok but I'm not sure that the yellow light comes on at >2k ; can't go on road as it's SORNed but I thought it used to when going in and out of garage so is this a clue? + can all these relays be faulty?
Thanks again
If as you say a normal switched relay runs the car just fine then you know the other relay terminals in the fusebox are all fine as are the fuel pump and wiring to it
'Stock' is the keyword - seems the pattern relays are both faulty or just don't work on my car for some reason.
Anyway, couple of jobs to do, get it MOT'd, off SORN and back in business.
Thanks again
David said
And it works!!!!
Thanks again
cool another toy on the road
On the drive
Myvalver 89 GTi Grey mk2 16v
