Fog Light Switch
(In Topic #220652)
Failed mot as my fog light switch’s little in-built bulb didn’t illuminate even though the switch works the rear fog light itself.
I researched the bulb could be replaced so I took it apart, cleaned contacts & put it back together wrong somehow. The bulb now works lol but now the switch is not ‘clicking’ properly & isn’t lighting the rear fog as before so I must have lost a part. Anyway I need a new switch but I have the front/rear combo switch which clicks twice, which is rare as rocking horse sh*t apparently. I cannot even find a used one for sale anywhere, VWH says 6-12 week lead time for a new one.
My question: I don’t have front fog lights anyway. I noticed the rear only fog switch has the exact same pin-out as my front/rear switch. If I buy this rear only switch, which is readily available, would it switch just the front fogs on or switch just the rear fog on or not work at all?
Why don't you see if the heated rear window switch works as that has a warning light I think, just put a sticker on saying rear fog and I can't see how the MOT tester could argue?
Good idea but the pin-out is totally different on the heated rear window switch so will not fit the fog loom plug.
Might be a bit extreme to swap/splice the wires over to the other switch but could be a last resort (assuming I can work out which wires are needed & go to what terminal on the other switch)
