fog light issues
(In Topic #196989)
Anyone know which pin on the headlight switch feeds power to pin 83 on the fog light switch ?
My rear fogs dont work, rang out all the wiring, the only thing i can find is no power to pin 83 on the plug for the fog lights ( headlights switched on)
Fuses and wiring ring out fine, head light switch to on but no 12v at the fog switch pin 83. Headlights work fine, wondering whether the headlight switch may be faulty?
May have to run a seperate power feed
You don't say what model / year of car you have. As the wiring can change from year to year. I found my wiring in my 83 Mk1 was to a Mk2 standard.
All I can say is that power to the foglight switch from the headlight switch is Not pin / terminal 83.
Terminals 83 a / b are the outputs from the foglight switch to the front & rear foglights. (a) being the front lights / first position of the switch, (b) being the rear foglights (plus front) / second position of the switch.
According to the Haynes, power input from fuse 27 mounted on top of the Fuse box, maybe via a Grey / Yellow wire, to the foglight switch is the "+" terminal at the foglight switch. I can't confirm the actual switch terminal number as my car is elsewhere.
I would suggest that you check to see if you have power at the Fog Switch "+" terminal when the headlights are on.
Of course the switch may have failed. Take the plug off the switch. Check continuity across the switch from the "+" terminal to 83b when the switch is in the second position.
Also check continuity from terminal 83b to the rear foglight, hopefully you will be able to see where to concentrate your fault finding.
Hope this helps.
Hope this helps.
Malcolm, thanks for your reply.
Its a 1983 1300 driver.
the grey and yellow wire on mine comes directly from plug B pin 20 on the fuseboard right up to the fog switch but has no power with the ignition on and the headlights switched on and continuity checks fine.
The fuse on top of the fuseboard on mine has a grey and white wire which comes from pin 83b on the fog switch running through it and have continuity checked it right back to the fog light socket in the tailll light assy.
Next step is figuring out which lead on the headlamp switch allows power to be applied to pin 20 on plug B to see if its the headlight switch or something else?
Adam
Adam
OK, you are correct, you do have a pin 83, you have a Mk2 relay board, hence the confusion on my part.
What you describe is exactly as it is in a Mk2 1300 wiring system. So the "+" is terminal 83 is an input to your foglight switch, 83a & b are the outputs. "a" via fuse 6. "b" via fuse 27.
Pin B20 goes to a "J5 Foglight relay" in position 7, bottom left, on your fuse board. It allow the "X" current to feed your switch.
This "X" current is supplied by Relay J59 position 8 on the fuse board. Positions I to 6 across the top, 7-12 across the bottom.
You know, I don't think the power comes from your headlight switch now, I believe it comes from the ignition being on and energising this "X" contact relay.
I suggest you test the two relays in 7 & 8, off the car, to see if they are working. A 9V battery or the car battery across 85 & 86 should hear the relays click and provide continuity across 30 & 87.
Ok, I am out now for a while See how it goes.
I think, you may well have found my issue!!!!!!
There is currently no relay in my position 7!!!
Any idea on the relay numbers for position 7 and 8 please?
Thank you for your help!
They are standard relays which you can buy from Halfords, some are rated though for the function they do.
However, what is the status of your car? Project / rebuild or daily driver?
Did the foglights work before you started work?
If they did, you might have a hybrid, you see on my car, I also do not have a relay in position 7, my fogs are wired up without a relay.
I suggest that you get a copy of the Mk1 wiring diagrams and the Mk2 to verify for reference before continuing.
Ah, my car was purchased as a project, so have no idea if it worked beforehand, but he had stripped out the fusebox so he could have removed anything. Perhaps i will have a swap around of relays to see if i can get it working!
If not it will be back to fault finding! A missing relay would certainly be a possibilty seeing as everything else seems to con check ok.
Cheers!
Cheers!
In that case, try a relay in position 7 first and then put another one in position 8.
Malcolm, your a star!!!
Im 99% certain now that the relay you highlighted is indeed required on my car! Unfortunatly i dont have a relay to check it with at the minute, but i ran my multimeter between the relay terminal at the fuseboard and + terminal at the fog lamp switch and it has continuity! Will try and source a 4 pin relay this week to get it sorted!
Thank you again Malcolm!!!!
You only have a relay if the car has front fogs, if this is the case then the grey/yellow wire spade behind fusebox goes to a mating connector on B/20 after you fit a relay.
for cars without front fogs the grey/yellow spade goes to M/1
http://www.clubgti.com/showthread.php?219775
also you only have a horn relay if you have dual tone horns, on the poverty spec with the weedy single tone you have a metal jumper pushed into the socket
Cheers RJ, but i cant find a spade on the grey/yellow at the back of the fusebox, there all seem to be straight into the main block plugs, then dissapear into looms!
Yeah i have a jumper on my horn relay but have put a relay on the twin air horns under the bonnet.
Got a number 12 relay on order to try in slot 7 to see if that cures my issues!
the b/20 spade may not be there on the mk1, it could just be a mk2 thing. As I say B/20 and fog light relay are only fitted to cars with front fogs from the factory, and its highly unlikely yours had them!
So follow the grey/yellow from your fog light switch it will(should!) run to a spade, pop that to M/1
Also since you have beeft horns now you want a 53 relay to run em, remove the jumper and pop in sorted. Not sure what a 12 relay is, its not in my list!
Still couldnt find a spade on the yellow/grey wiring, but the relay turned up and now i have fully working fogs!
Cheers for all the help!
You must have had factory fitted front fogs then! how rare
