Dx oil light flashing after above 2.5k for seconds
(In Topic #164955)
Just want to know what I need
Im guessing an oil pressure switch but which one
It's on an 88 dx cabby where is the switch and which one do I need to buy thanks
Just check which colours they are.
It could also be something else with your oil light flashing, faulty connection to the dash or there is a problem with oil pressure and your oil pump is on the way out.
Swap them for the ones above.
though if the light flashes above 2.5k the buzzer should also go off, if its not then your clocks may be duff or a bad earth somewhere. check the wires to the side of the head
