Dipped beam issues
(In Topic #199934)
Help
is there a separate relay for dipped/ main beam ? Or is it my stalk on the way out ? Any help please
thanks
ian
you should see 12v on the black/yellow wire on the ignition switch and light switch, then on the 2nd click of the light switch you should see 12v on the black/white wire. this one runs straight to the flasher switch so check the black/white wire here too for voltage.
while you're there check over all the ignition, stalk and light switch wiring over for general condition, look for melty wires/sockets, dirty contacts, exposed joints etc.
