80's blaupunkt speaker connectors
(In Topic #188428)
Hi,
Anyone know if these connectors/wires are still avaliable as I have look everywhere I can think of and with no luck!
Dan
Dan
I've seen them often on ebay.
I had to find some 18 months ago and you just have to play detective and spend a bit of time to get the ones you need.
Well I did!
Well I did!
Dan, Google '2 pin DIN speaker plug' and it'll throw up a few choices… Maplin and the like stock them for small change.
You can either get them with pre-moulded in wiring or just the plug itself (with screw terminals) should you need longer wires and want to do it yourself.
Life Member
I got some from a company in Barnsley who were Blaupunkt dealers. The connections are called 'dot-dash'.
The company is called Blaupunkt Direct, 01274 685411.
Not cheap from them but they were right and they last years so equal out over time!
My local independent traditional motor factors had some left from the 1980s - may be worht a try for you to look local.
Hi Guys
Thanks for the replies! I ended up getting old stock period ALTAI speaker leads for £3 off ebay. Thanks for your help!!
Dan
Dan
