91 Golf Clipper - Hinge in Glove Box
Replacing Hinges in Glove Box
Hi all! In my "new to me"  Cabby, one of the hinges is missing in the glove box used to open the door. I would like to replace both (seems easy enough), but I am having problems finding the correct hinges. Any ideas? Many thanks ! 067F8F29-1B19-4510-91E7-EA9287D48427.png
'91 VW Clipper Cabby, 5 speed, 1.8 (Weber with manual choke). I have no idea what I'm doing, so please show mercy.
  2857C4E6-41B8-46FE-84E5-8275A978BAFA.jpegw300 790E3798-CF8E-4797-8FF6-DDA39B680915.jpeg
need a better lighted pic, as it looks as if the hinge is there but the pin is missing, fo that you can buy a Dowel rod or a Screw/bolt for the pin.
Thanks so much - here's a better photo, with the parts circled. As you can (hopefully) see, the part on the right is fine and intact (it's what's holding the glove box door in - but the part is just old). The part on the left if missing all together (the screws are still there for some reason). So, I would need both the hinge part and the dowel 6B5CF172-BE45-4458-8796-58CAD0EF46D6.jpeg rod.
