Steering rack help,
(In Topic #217038)
I've recently fitted a steering rack on my caddy and there was a plastic thing inside the rack at the top
Where the wheel would sit, I presume it was to stop the steering wheel from moving, however I lost it , does anyone know what it's called ? I'm trying to source one and have had no Luck because I have no idea what's it called
Thanks again
Thanks again
I don't understand, where the wheel fits, do you mean rack or column.
It’s wjere the steering wheel attached there is lots of play, I remember there being a plastic bush that goes inside the column to stop it rattling around when the wheel is attached If that makes sense,Â
Thanks in
Thanks in
Could also be the white lower bearing out the bottom.
I know on my Green Cabby it fell down, and I pushed it back in place, then wire-tied it in place with a wide white tie.
Been that way for about 6 years so I considered it a permanent fix.
Thanks guys I'll look in to it, all I know is my steering wheel moves like a b—ger and I knew there was a plastic umbrella like type of thing on there and now there's not, I'll try anything thanks again for all your help !
Kris
Kris
