Seat runner plastic clips
(In Topic #188932)
Not a very good fit........
I bought some replacement runner clips hoping to sort out the front seat free-play; the problem is they seem too small.
I've fitted the new ones and the inner has a lots of space to move, it's worse than the old one!
I don't think there's anything wrong with the runners so I checked the clip sizes; the old one is slightly taller than the new one.
old clip 41.6mm - worn down along the bottom.
New clip 41.2mm - brand new, no wear
Am I doing something wrong here or are they just bad reproduction parts?
Have I got them the right way round?
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
I bought some from VW last year and they were fine, so it might be worth seeing if they still have any!
Repo rubbish
Think mk2 the same not 100%
bit of a pig to get back the runners sometimes bit of grease helps.
Don't suppose you know the VW Part number do you?
171 881 213 B
191 881 213
1983 Diamond Silver Mk1 GTi - Black Leather Interior - 16V ABF - Cable box - Upgraded Servo/MC and 280mm Disks - Coilovers - 15' Melbers
I have a related issue on the front Guide Piece.
My setup seems different, most pics Ive seen on this fitted looks like this
However I dont seem to have the hole that this guide secures into…
I managed to get these in, took some drilling and beating but got them in eventually. I now have a similarproblem as above my new plastic runner is not filling out the floor rail and I have some lateral movement.
Back to the drawing board but the movement is nowhere near as bad as before.
im back on this job again as i cant get these guides to set.
why are there 2 outer guides on EACH seat? - 171 881 213 B
where do these 2 guides fit?
I have 1 outer and 1 inner - why is there a need for a 2nd outer? and more important where does this 2nd outer guide fit ?
Does anyone have a pic of the seat with 3 guides fitted ? 1 inner and 2 outer?
as above, go to VW. 2.84+VAT each, part numbers are as above and you need 2 of each to do both seats (grey is outer, white is inner)
