Rust on rear arch
(In Topic #217601)
The rust on the rear arch wheel seens to have gotten worse and the paintwork has come off. Can anyone tell me what the best procedure i can do to treat this please?
I would say cut it out weld new metal, prep the weld, body bondo as needed, prime and paint
You need to remove the plastic wheel arch trim to see if the rust has spread from the wheel arch or if lucky it may be just surface rust. The plastic wheel arch can rub the paint in the area and that is what can cause the rusty metal.
You car may have been repainted at some point as the stone guard on the arch looks to be body colour so you may have to be carefully removing the arch incase they painted it in place….
Might be worth going to a body shop to price up a proper repair as any quick repair at home and if you don't grind/cut out all the rust will only last a couple of years before it comes back……
Rust on rear arch
Unless you have the means to paint it yourself after the work you might as well get it done at a body shop and as you’ve asked what to do on here I’m guessing this isn’t what you do for a living
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
Thanks for the replies guy - i will be making a trip down the body shop to see what they can do. I dint want the rust to re appear after few years.
Part of my master plan was to do a full respray at one point….i guess this is going to have to be done sooner than later. I use the golf as a daily and with the British weather it will only get worse…..
